Dear Developers,
I stumbled on your RC software and i found it very interesting. I downloaded it to my Phone (type see topic title).
The Phone uses A- GSP internal.
The program works but when i'm trying the settings for gps i can choose from 3 settings. Bluetooth GPS (don't have that one)
Serial GPS (is this internal?) and from file NMEA.
I tried to start a session with both, but none of them seem to work, I get the message "No fix to satalites" Any suggestions?
Greetings Arjan Wieme
"The windows GPS API is not supported. This means to use the internal GPS, you need to define a COM: port for it. Go to "Settings (Windows) > External GPS > Programs" and select a port in "GPS program port". Then go to RaceChrono settings and select the same port you just defined. "
another question is can i export a session to my PC?
Worked perfectly i may add, i had some dropouts according to the Performancebox software and i think one misreading -1.25 lateral G's on my way home.
The Lateral G's are a cumulative of all lateral measurements? and is there a way of showing only the max laterals?
wonderful sortware you have here :)
Got my hands on a Xperia X1i, GPS works fine in google maps, have tried the above (and many other thing) but can't get RC to work with the GPS. Any tips?
Running Windows Mobile 6.1 Professional and RC 1.4
