Racechrono DIY WiFi or USB support?
Hi @aol_of_RaceChrono would it be possible to add support for DIY via WiFi just like you have done with BLE? My current diy BLE setup has been working great, but since I have added a whole lot of new sensors (20 PIDs total), the total throughput over BLE per PID has dropped as it cannot keep up as there are many more PIDs and the BLE of my phone can't handle the throughput. It's gone from about 30hz each PID down to ~14hz with a total update rate around ~120hz. But ideally I want 50hz from most of these sensors which is not possible with the BLE. So would it be possible to add support for DIY using WiFi in the future, or even DIY via USB?
  • (keep in mind the tire temps you see here are using 1 PID per corner of the car) (and ignore speed FL, I have a faulty sensor)
