Hi all,
I try to import a nmea file with the import feature but it fails.
Here is the nmea file:
SAMPLE:
$GPVTG,0.000,T,0,M,25.547,N,47.313,K*53
$GPRMC,092217.000,V,4320.853,N,00620.169,E,11.09,0.00,191108,,*23
$GPGGA,092217.000,4320.853,N,00620.169,E,0,00,0.0,0.000,M,0.0,M,,*63
$GPVTG,0.000,T,0,M,11.090,N,20.538,K*55
$GPRMC,092218.000,V,4320.850,N,00620.167,E,9.99,0.00,191108,,*11
$GPGGA,092218.000,4320.850,N,00620.167,E,0,00,0.0,0.000,M,0.0,M,,*61
$GPVTG,0.000,T,0,M,9.990,N,18.502,K*67
$GPRMC,092219.000,V,4320.845,N,00620.169,E,9.53,0.00,191108,,*1C
$GPGGA,092219.000,4320.845,N,00620.169,E,0,00,0.0,0.000,M,0.0,M,,*6A
$GPVTG,0.000,T,0,M,9.534,N,17.657,K*69
$GPRMC,092220.000,V,4320.839,N,00620.179,E,21.44,0.00,191108,,*20
$GPGGA,092220.000,4320.839,N,00620.179,E,0,00,0.0,0.000,M,0.0,M,,*6A
$GPVTG,0.000,T,0,M,21.439,N,39.705,K*55
$GPRMC,092221.000,V,4320.837,N,00620.188,E,24.33,0.00,191108,,*24
$GPGGA,092221.000,4320.837,N,00620.188,E,0,00,0.0,0.000,M,0.0,M,,*6B
The result is that it imports 0km !
Screenshot:
What am I doing wrong.
Thank you for your help!
I am not at home currentl, sunday monday; I ll send it to you.
in any case, thank you!
Bye
It seems the adress you gave me is invalid.
(you can download the file here http://vallauri.org/files/tools.zip )
Technical details of permanent failure:
Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 550 550 5.1.1 <trac....> Recipient address rejected: User unknown in virtual alias table (state 14).
I hope you have enaught to work on the issue, in case you need something else, please tell me.
Good bye
I'm new here in ths forum and I recently wanted to use RaceChrono to process GPS data that was recorded at 5 Hz on a BT747A+ gps receiver. However, with my NMEA-file, I get the same issue as kbumbaz (0 km traveled route). Is there any fix for this issue in the meantime?
Best regards,
schluerfi1978
Sample out of my NMEA file:
$GPRMC,130122.800,A,5007.568781,N,00853.501353,E,2.277,315.438843,050909,,,A*5F
$GPGGA,130122.800,5007.5688,N,00853.5014,E,1,,,110.534,M,47.8,M,,*7F
$GPZDA,130122.800,05,09,2009,,*5A
$GPRMC,130127.800,A,5007.583620,N,00853.514814,E,1.722,67.364876,050909,,,A*61
$GPGGA,130127.800,5007.5836,N,00853.5148,E,1,,,122.642,M,47.8,M,,*7A
$GPZDA,130127.800,05,09,2009,,*5F
$GPRMC,130132.800,A,5007.584430,N,00853.514783,E,2.566,76.159523,050909,,,A*60
$GPGGA,130132.800,5007.5844,N,00853.5148,E,1,,,113.229,M,47.8,M,,*70
$GPZDA,130132.800,05,09,2009,,*5B
I sent the file to the e-mail above earlier this afternoon. Hope you're not having problems with it due to file size.
To compare the steering, I give it (the BT747) to another pilot, better or worse than me.
Comparison with others is very informative!
Motorcycle people accept a very small thing like the bt747.
So if you're going to do with an iPaq hx2410 and a bt747, they meet often not.
Well !
When I finished my or another pilot session on the track I download over bluetooth the log file "BT747log.bin" on a my iPaq pocket pc (wm2003se) with "bt747 MTK Logger Control" PDA-Version (need SuperWaba, it's very hard to install java with specs CLDC 1.1/MIDP2.0/JSR82 on a pocket pc !)
This software is available at "http://www.haased.de/gps_ge/bt747_start.html"
Set BT747 :
- record data time fix to 200ms !
- don't activate "overwrite when full", this option would force full downloads instead of incremental (smart) ones. A bluetooth full download is very, very long ...
I convert it to nmea file and import to racechrono ! Don't work ... the satellite count field !!!
Yes, yes I know ... I get the same issue as schluerfi1978.
And finally, it's not too early eh, I'm very talkative ...
I just want to talk about this particular way of using racechrono.
Who excels at comparing different ways of driving on tracks.
I export a nmea file with Racechrono, i open it, i see GGA,GSA,GSV,RMC.
I convert file "BT747log.bin" with "bt747 MTK Logger Control", i open it, i see GGA, RMC, ZDA.
Missing GSA (GPS DOP and active satellites) and GSV (Satellites in View)
"bt747 MTK Logger Control" allows to change the NMEA sequences in "BT747log.bin" file
I test this ...
A little question to aol : What are the NMEA sentences used by racechrono ?
ZDA no use ?
All parameters BT747 are set to original values, i get this log file:
$GPRMC,173110,A,XXXX.045987,N,XXXXX.468420,E,0.004,,150210,,,A*XX
$GPGGA,173110,XXXX.0460,N,XXXXX.4684,E,1,,,15.967,M,49.2,M,,*XX
$GPZDA,173110,15,02,2010,,*48
All parameters BT747 are original values, except NSAT activation in FMT tab, i get this log file:
$GPRMC,171803,A,XXXX.045497,N,XXXXX.468606,E,0.003,,150210,,,A*XX
$GPGGA,171803,XXXX.0455,N,XXXXX.4686,E,1,9,,11.632,M,49.2,M,,*XX
$GPZDA,171803,15,02,2010,,*41
Ending >>
RMC sentence : no difference !
GGA sentence : view satellite number, here is 9 !
Operations order make with "BT747 - MTK Logger Control":
Set parameters & erase log, activate log, get log, convert to nmea file.
I have succesfully import nmea file to Racechrono v 1.36
My iBlue setup is default except log 5hz (for race is better) and in the recording format,
I turned on : Heading, Nsat, Millisecond.
To configure it, you need a program like :
- For java PC
"BT747 Data Logger Software"
www.bt747.org
- For Pocket PC
- For Phone list go to
http://www.getjar.com/mobile/17413/bt747---bt_j2me-midlet-suite/?s=phones
I configure iBlue747 with my Nokia 6131 !!!
For minimize the size of log in the iBlue internal memory and thus minimize the download time(bluetooth 1.2 is slower than usb), can you tell us the nmea sentences need to Racechrono to function properly.
If I understand the minimal $GP is :
RMC, GGA = required
ZDA = you say "ZDA is useful too but only with combination with RMC or GGA", for a minimal file can do without ?
GSV = I don't know
In detail :
milliseconds in "time fix taken at" = I don't know
with the track angle (heading) in RMC = required !
number of satellites being tracked in GGA = desirable for version 1.4 and required for earlier Racechrono versions
horizontal dilution of position (HDOP) in GGA = I don't know
There is a bit off topic but I just found out that meant NMEA : The National Marine Electronics Association. Ok !
This is according to the principle of minimum. You can add, but reduce the recording time.
I tested various combinations with RaceChrono v1.36 and v1.40
$GP Sentences required : RMC GGA
Data required for RMC
All, except "Magnetic variation".
The first field "time fix taken at" must specify the milliseconds !!!
Example :
$GPRMC,212318.800,A,0000.056864,N,00000.466294,E,0.026,19.415201,170210,,,A*64
Data required for GGA
all, except :
- HDOP (Horizontal dilution of position)
- NSat (Number of satellites being tracked), but see Note.
- DGPS data
Example (with NSat, 9 here) :
$GPGGA,212322.000,0000.0570,N,00000.4661,E,1,9,,18.697,M,49.2,M,,*71
Note : only for RC v1.4, is required for RC v1.36
But it's better with ! You can appreciate the quality of the satellite reception with the color of the trace in the Splits mode.
With common GPS recorder,
you MUST activate in data logger : UTC,VALID,LATITUDE,LONGITUDE,HEIGHT,SPEED,HEADING,NSAT,MILLISECOND
Import settings nmea FILE : RMC and GGA
With the "iBlue747A+" and the DEFAULT settings,
you MUST activate in format :
HEADING, NSAT, MILLISECOND
and you can unactivate in format : RCR (record reason, take 2bits per record)
"iBlue747A+" have 4Mbytes memory and my setup take 40bytes per record.
With this setup I can record 5h50min in 5hz log.
Important things about "iBlue747A+": this GPS recorder keep 5hz fix but with default parameter ever loose 5hz log, after switching in log you must set time to 0.2s (ie 5hz log) !
If you want keep 5hz log after power off, set this in Log conditions :
- don't check time
- don't check distance
- check speed and enter the value you want, I tested successfully 1km/h, 5km/h and 10km/h.
If satellite reception is poor (<8 SAT) does not go below 5km/h, otherwise you'll save garbage values.
With proper configuration of your GPS Logger, RaceChrono import nmea files correctly.
i am new to this topic (gps logging). few days ago i bought a qstarz bt 1000ex an recorded my first track and exported it with the qstarz software as nmea-file. this file wasn`t accepted by racechrono. after reading this thread i installed the "MTK Data Logger Control BT747" and tried to config my logger the right way. my biggest problem is that the downloaded file can`t be exported as nmea-file due to unknown problems. i tried many different methods of filters but it still doesn`t work...
could anyone give me a hint solving this problem?
i worked on the problem but did not get a full solution to the problem.
still working with "MTK Data Logger Control BT747" i exported a nmea-file with these sequences:
$GPRMC,134823.400,,5116.223185,N,00713.262010,E,3.975,117.009705,300310,,,A*1F
$GPGGA,134823.400,5116.2232,N,00713.2620,E,,4,7.45,110.211,M,47.0,M,,*64
$GPZDA,134823.400,30,03,2010,,*5E
main difference to an working gpslog is in RMC the missing "A" and in GGA a "," to much after the "E"
the settings for the logger and that export can you see in the following jpegs:
logger settings 1: http://www.imagebanana.com/img/4rw4tfgb/gert1nmea.JPG
logger settings 2: http://www.imagebanana.com/img/z1sd8mvl/gert2nmea.JPG
filter for export: http://www.imagebanana.com/img/l2br0m1b/filternmea.JPG
export settings: http://www.imagebanana.com/img/jft0fbkn/ausgabenmea.JPG
i would be glad if someone could tell me with settings to switch on to get rid of those to mistakes in my gpslogs.
greetings ingo
will be at the nürburgring gp track at the end of april
I am having a hard time importing GPS data from my data logger onto RaceChrono. I have all the required fields according to hugos above post.
Orginal file: 10042003.CVS
Converted Orginal to NMEA format usign GPSVisulizer: 10042003_1.NMEA
Changed the Satalite count in $GPGGA string from 00 to 9: 10042003_2.NMEA
Changed the Satalite count in $GPGGA string from 9 to 09: 10042003_3.NMEA
Sample NMEA strings taken from 10042003_3.NMEA:
$GPRMC,130918.000,A,5056.216,N,11404.623,W,3.78,0.00,200410,,*1C
$GPGGA,130918.000,5056.216,N,11404.623,W,1,09,1.3,1081.000,M,0.0,M,,*42
$GPVTG,0.000,T,0,M,3.780,N,7.000,K*5B
$GPGSA,A,3,,,,,,,,,,,,,1.5,1.3,0.9*3D
$GPRMC,130919.000,A,5056.211,N,11404.619,W,4.86,0.00,200410,,*15
$GPGGA,130919.000,5056.211,N,11404.619,W,1,09,0.9,1076.000,M,0.0,M,,*4E
$GPVTG,0.000,T,0,M,4.860,N,9.000,K*53
$GPGSA,A,3,,,,,,,,,,,,,1.2,0.9,0.8*30
$GPRMC,130920.000,A,5056.210,N,11404.616,W,5.94,90.00,200410,,*2A
$GPGGA,130920.000,5056.210,N,11404.616,W,1,09,0.9,1075.000,M,0.0,M,,*49
$GPVTG,90.000,T,0,M,5.940,N,11.000,K*51
$GPRMC,130921.000,A,5056.210,N,11404.614,W,5.94,91.00,200410,,*28
$GPGGA,130921.000,5056.210,N,11404.614,W,1,09,0.9,1074.000,M,0.0,M,,*4B
GPSBabel online conversion tool >> http://www.gpsvisualizer.com/gpsbabel/gpsbabel_convert
DataLogger >> Columbus V900
SW >> RaceChrono for Windows 1.4
Previous Sessions > Import New > Import file (browse to file) > Session title (input name) > Start
GPS data can be downloaded from here: http://rapidshare.com/files/378241552/GPS_Data.zip.html
Thanks for any help
