I appreciate that this function will never be that accurate but I have got very odd results from initial tests.
My car which will do 0-60 in around 3 secs, did 2 runs in the mid 7s. This was with a bluetooth gps receiver being used (BT-368 from GlobalSat). This was clearly miles off so I repeated the test with the internal gps on the phone (Nokia 5800) and it registered 4.4 s on a much less agressive attempt.
Have I got a useless external GPS receiver or do I need to change a setting ?
Thnx any help.
D
Dont worry - I am using this for lap timing - so the performance testing is just me playing with it to get used to what it can do. But in that, I wanted to find the best way of getting accurate lap results and if my receiver is rubbish I will get the one u recommend.
The one I have also gave a very flat line on the graph - clearly wrong as it didnt reflect gear changes, which the internal gps did. So on track if the data isnt coming over quick enough it will be useless.
I assume best bet is to just buy the Gps receiver recommended ?
D
tia,
Tried some different runs, and the times seem plausible, but it would be nice to know what kind of accuracy can be expected.
The OBD data is updated about 3 times per second as far as I can tell, while the GPS data looks like interpolated 1hz data (since the GPS is 1hz, that's as expected I guess).
Still not wiser though... I have slightly bigger tires than the original dimension (at least on my street tires), so that would mean the OBD speed is a bit lower then my real speed, 3km/h is probably in the region I guess (205/45R17 original and 215/45R17 on now).
How about if I find a slight disrepance, like one is a few km/h faster than the other? And if say the OBD speed is slightly lower, does that mean I have a slight error on the negative side (meaning my times are slightly worse than actual performance)?
Thanks for the prompt replies!
Gotta take a look at those "Donate" buttons soon I think, but unfortunately not until next month because my car is going in for some work and it'll probably leave me on rice and beans for the rest of the month :-)
