Extract from HTC Desire
edited July 2012 in RaceChrono for Android
I recently started using RACECHRONO on my android phone, HTC Desire Android 2.2.2
Using the phone, and its internal GPS is great but I would use the data on PC, and there I block.
I searched a bit on the net but I have not found my happiness.
What is the procedure to operate phone data on PC??
Thank you in advance, see you soon.
(sorry for English, but I suck ... then google translation)
  • edited July 2012
    Hello, I did the update today.
    I open a session with different start and finish.
    Export session ... OK
    The creation of NMEA file on the phone ... OK
    I copy the file to the PC ... OK
    Import the file with RACECHRONO ... OK
    And then nothing ...
    I see no trace, I can not add start / finish line.
    "Traveled way" = Duration: 0 (0KB)
    Can anyone help me?
    thank you in advance
  • edited July 2012
    Oh no, I screwed it up little bit. The exporting on v2.05 uses decimal separator from locale. So it breaks up at least on French and Finnish locale, as the separator needs to be always a dot. I'll make a hotfix v2.06...
    Thanks for pointing out to problem so quickly!
  • no problem, if I can help a little ;-)
  • Uploaded fixed v2.06 to Play Store, it should be available in two-three hours from now.
  • Ok, whenever I can I tell if it works well.
  • it's good, it works well.
    application even better now.
    Thank you.
