Negative numbers in export
I've encountered a strange problem with the export to CSV files. The minus sign in negative numbers is the Unicode "Minus sign" character (U2212) instead of the customary ASCII hyphen-minus (x2D). The Unicode is then encoded as UTF-8 and appears in the file as the bytes E2 88 92. This is on an Xperia x10 mini with Android 2.1 and Swedish regional settings, the export files are then copied to a Win 7 PC.
This not a big deal (although mildly annoying) since it is easy to do a search and replace to correct the problem.
  • edited August 2012
    I cannot reproduce, but I made a manual locale override for the minus sign on exporting. It should fix this. I will release a fixed version maybe in one week time. Thanks for the bug report!
