Change log for RaceChrono v2.21 for Android
March 16th, 2013 by aol
Change log for RaceChrono v2.21 for Android (16.3.2012):
  • Fixed: Broken NMEA exporting
  • Fixed: Crash when exiting track editor before track was loaded
  • Fixed: Possibly some other crashes
Change log for RaceChrono v2.20 for Android (24.2.2012):
  • Finally implemented Standing Start traps
  • Configurable high/low markers in analyzing map. By default this is configured to Speed, which shows up corner and straight speeds nicely.
  • Configurable driving line color in analyzing map. By default this is configured to Longitudinal Acceleration, which shows up braking and acceleration points.
  • Graph map can be changed between Satellite, Roadmap and Simple modes. Simple mode has just black background, so it does not cause any data transfer.
  • Added support for hardware accelerated graphics
  • An ‘Update rate’ channel added for all devices
  • New easier to use live timer
  • Dropped Android 2.1 support (devices with Android 2.1 will get the RaceChrono v2.11 from Play Store)
  • Improved graphics and usability in track editor
  • Fixed: Duplicate data was saved when stopped recording at certain multiples (of number of data points)
  • Fixed: Delay occurred when opening long sessions
Change log for RaceChrono v2.11 for Android (16.9.2012):
  • Added Garmin GLO support (an excellent 10 Hz Bluetooth GPS/GLONASS receiver)
  • Added track counts to Track Library
  • Fixed: Broken support for some Bluetooth GPS receivers on Android 4.x (Atleast some Holux models)
  • Fixed: Reloading Track Library did not properly update Unofficial and Pending review category
  • Fixed: Pending review category in Track Library was missing most of the tracks
Change log for RaceChrono v2.10 for Android (10.9.2012):
  • Selectible absolute or relative timing in lap list
  • Selectible “Sectors” and “Splits” mode in lap list (“Trap speed” and “Hi/lo speeds” coming later)
  • Quick selection for lap and comparison lap when analyzing laps
  • Quick selection for session fragment when analyzing session route
  • Comparison graph is now drawn also when analyzing sectors
  • Added Refresh button in session list
  • Add example track and session to the package
  • Added expert setting “Do not modify GPS” to disable modification of MTK chipset settings
  • Added expert setting “Record internal sensors” to enable recording of internal accelerometer and gyroscope (note this is an experimental feature that may be changed or removed later)
  • Fixed: Optimal lap calculation (occurred when some laps had missed split traps)
  • Fixed: Text on map flags did not scale according to screen pixel density
  • Fixed: Crash when opened graph settings when session was still empty
  • Fixed: Rare crash when exiting track editor
  • Fixed: Wrong minus symbol on exports on some locale
  • Fixed: Invalid comparison graph after switching track
  • Fixed: Refresh button logic in track list
Change log for RaceChrono v2.06 for Android (23.7.2012):
  • Fixed: Exporting was broken when using locales with comma decimal separator (French, Finnish)…
  • Fixed: Rare crash when stopping recording
Change log for RaceChrono v2.05 for Android (22.7.2012):
  • Dropped the beta postfix!
  • Session exporting to CSV and NMEA 0183 formats. The CSV format is tested with RaceRender2, DashWare and RaceChrono2AVI video generators.
  • Added lateral and longitudinal acceleration channels calculated from GPS data
  • Fixed: Now ignoring data if GPS time goes backwards
Change log for RaceChrono v2.04 beta for Android (3.7.2012):
  • Fixed: Samsung Galaxy S2 with Android 4.0.3 had Bluetooth problems. I created a workaround to keep the Bluetooth connection alive.
  • Fixed: Rare graph crash
  • Fixed: Virtual keyboard was not hidden correctly in track editor
  • Fixed: Entered name was lost while editing the trap
Change log for RaceChrono v2.03 beta for Android (11.6.2012):
  • Fixed: Crash when opening very long sessions (>100 laps without pausing)
Change log for RaceChrono v2.02 beta for Android (10.6.2012):
  • Fixed: Automatic track detection crashed the app frequently (bug introduced in v2.01)
Change log for RaceChrono v2.01 beta for Android (9.6.2012):
  • Longer battery life when recording (less CPU usage)
  • Fixed: Automatic track detection worked only on first session (since application start)
  • Fixed: Automatic track detection did not work if not signed in to My RaceChrono
  • Fixed: Rare crash when recording or opening session
  • Fixed: Crash when opening track editor when latest session (or resume) had no plots
  • Fixed: Track editor was in invalid state after removing traps
  • Fixed: Graph/Driving line was not visible (at first) in Route analyzer
Change log for RaceChrono v2.00.7 beta for Android (3.6.2012), since Preview4:
  • Main screen now allows landscape mode.
  • Created settings view with metric/english units, device configuration etc.
  • Added features for managing My RaceChrono account.
  • Warning is displayed if internal GPS is used but it is not enabled.
  • Warning/Disclaimer pop-up appers on application start-up. This can be disabled from settings.
  • Improved icons
  • Fixed: Could not use the app after USB storage was first mounted, but unmounted afterwards.
  • Fixed: Multiple crashes when viewing graphs
  • Fixed: Nearby tracks list sorting issue
13 Responses to “Change log for RaceChrono v2.21 for Android”
  1. Andrey Says:
    Can’t update old version – G Play doesn’t show “update” button while I definately see that my version currently installed is old one.
  2. Andrey Says:
    SOLVED! Installed new version by downloading .apk file from your site. Had to turn on external sources…
    For some reason app is not shown in the list when i open “My apps” in GPlay. Anyway – works fine now, Thanks!
  3. Axon Says:
    Good job !
    Vocal synthétiser, is it possible to add ?
  4. gtommi Says:
    “Added expert setting “Do not modify GPS” to disable modification of MTK chipset settings”
    When, where and why useful this settings?
  5. aol Says:
    gtommi: Only if you’re modifying GPS settings manually and don’t want RaceChrono to override them
  6. Jaco2k Says:
    Is there any ETA for OBD? ;)
  7. gtommi Says:
    Thanks!
  8. lolloterror Says:
    Hello Antti,
    I got problems whit a chinese android device, it seems that cannot see the GPS (qstarz 810) with the racechrono app, with other GPS log apps it works!
    Pls help me for this issue!
    Thanks
  9. lolloterror Says:
    I forgot to say that on my Chinese android device is installed Android 2.3.4 version.
    Thanks
  10. lolloterror Says:
    update, I tried the same 2.11 version on an HTC Wildfire with Android 2.2 and also with this device was impossible to connect the external GPS, is it a bug?
    Thanks
  11. Kawiman Says:
    Excellent, this was actually the only reason why I kept my WM6 phone and while there were similar apps for android, it is still second to none.
    One single complain would be the lack of performance tests which were available in the old version. Is it planned to include it?
    Other question is whether there is a way to donate the development?
    Thanks
  12. aol Says:
    Kawlman: Performance testing is quite common request, and I do plan to include it once I’m happy with the lap timing features. You can donate at http://www.racechrono.com/download/ (see the donate button at the top).
  13. Ian Hendra Says:
    MyRaceChrono sign-in is Bigfla. I use a Samsung Galaxy S2. Questions for you, please.
    1. Does your pdf manual apply to the Android version?
    2. How do I get to MyRaceChrono?
    3. Is there a video mode (like Trackmaster or Harry’s Lap Timer for the iPhone)?4. How do I use racechrono2avi to make overlays on videos (eg from Trackmaster)?
    By the way, I prefer the look and feel of RaceChrono to Trackmaster.
    Thanks
Leave a Reply
