watching all your data on your phone or tablet is fine but a bit small, so ive done this guide for anyone unsure how to transfer to PC for big screen playback.
firstly download and install Bluestacks from here
http://bit.ly/bstkdnldpageSign in using your Play account and download Racechrono and ESfile explorer this is need for moving the files in Bluestacks
Next make sure you can view hidden folders on you PC
1.Open Folder Options by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options.
2.Click the View tab.
3.Under Advanced settings, click Show hidden files, folders, and drives, and then click OK.
this will let you locate C:\ProgramData\BlueStacks\UserData\SharedFolder
Plug your Phone into your pc and first find the Video data if you are using PRO this is located In DCIM/RaceChrono
move the whole file into C:\ProgramData\BlueStacks\UserData\SharedFolder
In Bluestacks Start Esfile explorer and go to/sdcard/bstfolder/BstSharedFolder there you should find the Racechrone file you just copied from your phone.
Long left click and select CUT, this folder needs moved to /mnt/sdcard/DCIM
Next is the main Racechrono file locate it on your phone and again transfer to C:\ProgramData\BlueStacks\UserData\SharedFolder
back to Esfile explorer and /sdcard/bstfolder/BstSharedFolder you may need to refresh to find the new file.
Cut this as before and move to /mnt/sdcard where a racechrono file already exists Overwrite when asked
finally exit Esfile explorer start Racechrono go to sessions and there you go
